Desktop/Copy of GPS_TRACE/SRC/RS232.h File Reference
This graph shows which files directly or indirectly include this file:
Go to the source code of this file.
Functions
void uart0_init ()
void uart0_putc (unsigned char c)
 initialize UART0
void uart0_puts (char *s)
 put char to UART0
void uart0_send_initial_char ()
 put string to UART0
void uart1_init ()
 Send initials char to UART0.
void uart1_putc (unsigned char c)
 initialize UART1
void uart1_puts (char *s)
 put char to UART1
void uart1_send_initial_char ()
 put string UART1
Function Documentation
void uart0_init (  )
void uart0_putc ( unsigned char  c  )
initialize UART0
Parameters:
none
Returns:
none
Definition at line 21 of file RS232.c.
void uart0_puts ( char *  s  )
put char to UART0
Parameters:
none
Returns:
none
Definition at line 28 of file RS232.c.
References uart0_putc().
void uart0_send_initial_char (  )
put string to UART0
Parameters:
none
Returns:
none
Definition at line 36 of file RS232.c.
void uart1_init (  )
Parameters:
none
Returns:
none
Definition at line 44 of file RS232.c.
References F_OSC, UART_BAUD_CALC, and UART_BAUD_RATE.
void uart1_putc ( unsigned char  c  )
initialize UART1
Parameters:
none
Returns:
none
Definition at line 57 of file RS232.c.
void uart1_puts ( char *  s  )
put char to UART1
Parameters:
none
Returns:
none
Definition at line 64 of file RS232.c.
References uart1_putc().
void uart1_send_initial_char (  )
put string UART1
Parameters:
none
Returns:
none
Definition at line 73 of file RS232.c.
Generated on Fri Aug 17 13:50:56 2007 for GPS TRACE by  doxygen 1.5.3
